Biomedical device fabrication
Hello everyone! I am Federico,
I am looking for useful information regarding the fabrication technique and consequently the most suitable materials for manufacturing a device for use in biomedical research. Specifically, the device is about 15x3x3 cm in size and has many empty spaces and channels inside. I am interested in identifying the fabrication method that will allow me to ensure a good accuracy of the geometry, possibly without spending too much money (no exaggeratedly high accuracy required, no too small components). In your opinion, could HP Multi Jet Fusion be a good solution? And possibly, can PP be a good material? I know it is often used for biomedical applications due to its hydrophobic and chemical inert capabilities; however, the part will need to be in a 37°C and high humidity environment for a long time.
Thank you very much to anyone who can help me!
Federico
Gelöst vonNikolaus Mroncz
Hi Frederico,
nice to meet you and thank you for your question.
For a humid environment it would help to have a closed surface. In MJF we have a postprocessing, called vapour smoothing which seals the surface completely.
It is not so successful with PP. But PA12 in MJF could be a good solution here.
If necessary we could you also a printing in ISO 13485. This would be in SLS and PA12.
Hope this answers your questions.
best regards
    • Hello everyone! I am Federico,
      Federico
      Hi Frederico,
      best regards
      Hello, Federico,
      How fine are the features/channels that you are referring to? Maybe you could also share a screenshot with some of the features – just to take a look and assess whether MJF/SLS can be a good solution here?
Deine Information:
Ergonomischer Handwerkzeuggriff: Überformen oder was anderes?
Hallo zusammen, ich bin in den frühen Phasen der Entwicklung eines neuen Handwerkzeugs (Drahtschneider). Das Werkzeug benötigt einen ergonomischen Griff, der auch bei längerem Gebrauch einen guten Halt und Komfort bietet. Ich überlege verschiedene... Mehr erfahren
Jun 11
Auswirkung der FDM-Schichtdicke auf die Festigkeit
Hallo! Ich konstruiere gerade eine hochbelastbare Komponente für Industrieanlagen und verwende dafür ein hochfestes Polymer wie Ultem 1010 oder PC (FDM-Druck). Das Bauteil muss erheblichen Stress und Aufprall aushalten. Ich schwanke zwischen einer Schichtdicke... Mehr erfahren
Mai 24
Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think... Mehr erfahren
Jun 04
Hi everyone, I would appreciate additional information regarding the optimal choice for my project. I’m going to print a tablet mount that must be robust and durable to hold my device. What might be... Mehr erfahren
Mai 17
Hello,I am to order some laser cut sheet metal of steel, and got some technical questions, maybe someone can help: – TolerancesFrom what I have heard, the diameter of the laser beam is typically 0.2-o.3mm... Mehr erfahren
Mai 03
