FDM finish options to smoothen the surface
Hi everyone, I’m planning to 3D print a part using FDM technology, but I’m concerned about the visible layer lines that typically appear on the surface. Does anyone have experience with effective techniques to achieve a smoother finish, such as sanding, chemical vapor polishing, or similar methods?
Gelöst vonNikolaus Mroncz
Dear Heinrich, vapor smoothing for FDM 3D prints is indeed good for smoothing out layer lines. You may just want to keep in mind that it will also affect the dimensional accuracy of the part quite a bit, because the process dissolves the outer shell of your print. There are various grades of vapor smoothing, and in the highest grade, the process will dissolve details and sharp edges.
If you need a preliminary finish to smoothen the surface before painting for instance, then sanding with grit sandpaper (150, 220, 400) is an option. Please note that it is not suitable for intricate surfaces and small details.
And finally, you can also apply an epoxy coating – it is suitable for all FDM thermoplastics. It smooths out any remaining imperfections and also adds a layer of resin to the printed part that fills the gaps.
    • H
    • m
      Hello Heinrich, chemical vapor smoothing is a solid choice—it involves exposing the print to a solvent vapor that lightly melts the surface, smoothing out those layer lines and boosting the look. This technique works really well for ABS and certain types of PLA.
    • H
      Thanks everyone for the detailed advice! Since I’m looking for a more robust finish, then epoxy coating sounds like a good option.
Deine Information:
Vergleich von Nylon 12 (PA 12) SLS mit PA6 GF30
Frage zu Nylon 12 (PA 12) glasfaserverstärkt (SLS) - ist das oben genannte Verfahren und Material am besten mit dem Material PA6 GF30 vergleichbar?
Mai 02
3D-Druck – dekorative Elemente
Hallo zusammen, ich möchte einige schlanke Dekorteile (sie sind 1,5-2 mm dick) für ein Musikinstrument mittels 3D-Druck herstellen lassen. Im Anhang findet ihr einen Screenshot eines der Modelle zur Ansicht. Könntet ihr spezielle Technologien... Mehr erfahren
719
Apr 30
PA12 und chemische Dampfglättung: Beständigkeit gegen Meerwasser?
Guten Tag, Ich habe eine kleine Frage: hält chemisch dampfgeglättetes PA12 (mit SLS/MJF) gut in Meerwasserbedingungen? Ich überlege, es für Teile zu verwenden, die häufig Meerwasserbedingungen ausgesetzt sind. Ich weiß, dass chemische Dampfglättung die... Mehr erfahren
Benötige Empfehlungen für eine feste Aluminiumlegierung
Hallo, ich entwerfe einen Flaschenöffner und möchte Aluminium verwenden. Ich brauche eine Legierung, die stark genug ist. Der Öffner wird nicht sehr dünn sein, ich denke an 3-4 mm an den dünnsten Stellen, so... Mehr erfahren
Mrz 11
Hello,I'm working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I'm looking into CNC machining as injection molding seems not to be an option due to the precision... Mehr erfahren
Z
316
Jun 12
