Z
Hello,
I’m working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I’m looking into CNC machining as injection molding seems not to be an option due to the precision required.
Maybe anyone could advise what flame retardant plastics should I consider for cnc that have UL recognition or certification? Ensuring the material meets safety standards is crucial for my application. Thank you, would appreciate any recommendations
    • Z
      Hello,
      Hi and thanks for your question. In CNC we have an ABS and Peek material rated UL94V0. Please add this demands in the comment, if you order at Xometry, there different grades are available.
      BR
      • Z
        Nikolaus Mroncz
        Hi,Nikolaus, thank you for your comment
    • Senior Content Manager
      Hi Zdenek,
      To complete Niko’s answer, you can check this detailed article about flame retardant materials https://xometry.pro/en-eu/articles/flame-retardant-plastics-ul-94/ You’ll find a list of materials which are, for most of them, UL 94 V-0 rated.
      I also would like to bring your attention to the fact that depending on your application, V-0 rating might not be necessary and you could consider V-2 or V-1 (or maybe even HB) rated materials. The grade of flame retardancy should be chosen based on the part, its application, and the environment in which it will be used.
      • Z
        Manon Bouriaud
        Hi Manon, good points indeed, thanks for sharing!
Deine Information:
Vergleich von Nylon 12 (PA 12) SLS mit PA6 GF30
Frage zu Nylon 12 (PA 12) glasfaserverstärkt (SLS) - ist das oben genannte Verfahren und Material am besten mit dem Material PA6 GF30 vergleichbar?
Mai 02
3D-Druck – dekorative Elemente
Hallo zusammen, ich möchte einige schlanke Dekorteile (sie sind 1,5-2 mm dick) für ein Musikinstrument mittels 3D-Druck herstellen lassen. Im Anhang findet ihr einen Screenshot eines der Modelle zur Ansicht. Könntet ihr spezielle Technologien... Mehr erfahren
693
Apr 30
PA12 und chemische Dampfglättung: Beständigkeit gegen Meerwasser?
Guten Tag, Ich habe eine kleine Frage: hält chemisch dampfgeglättetes PA12 (mit SLS/MJF) gut in Meerwasserbedingungen? Ich überlege, es für Teile zu verwenden, die häufig Meerwasserbedingungen ausgesetzt sind. Ich weiß, dass chemische Dampfglättung die... Mehr erfahren
Benötige Empfehlungen für eine feste Aluminiumlegierung
Hallo, ich entwerfe einen Flaschenöffner und möchte Aluminium verwenden. Ich brauche eine Legierung, die stark genug ist. Der Öffner wird nicht sehr dünn sein, ich denke an 3-4 mm an den dünnsten Stellen, so... Mehr erfahren
Mrz 11
Mai 29
