Material Information
Good morning everyone,
I am intending to fabricate a model for biomedical applications, and the Xometry staff has suggested stereolithography as the fabrication method and Industrial Transparent ABS-like material, which can meet the basic requirements (strength, low moisture absorption, and transparency).
My concern is about its prolonged use, especially if in contact with liquids that will in turn come in contact with biological material. An additional problem is reuse of the part, that is, between uses it will be necessary to sterilize the part, and since it does not withstand autoclave temperatures, the only way available to me is with ethanol. Does this lead to damage to the material?
Thank you in advance for anyone who can help and give me an answer.
Good day to all,
Federico
    • Good morning everyone,
      Good day to all,
      Federico
      Hello Federico,
      Have you considered other manufacturing technologies, e.g. injection moulding? Or are you limited to only 3D printing?
        Tilmann98
        Good point, I also think that the choice for transparent materials in 3D printing is quite limited. You can add e.g. lacquering to ensure better usability and prolong its use, but still it’s not comparable to injection moulded transparent parts with e.g. ABS LG TR558A
      Hi Frederico,
      the SLA translucent is good to make first trails, to sterilize and reuse might be challengin,g there I expect the material to age quite fast. For this kind of applications injection molded parts are best.
      BR
Deine Information:
Vergleich von Nylon 12 (PA 12) SLS mit PA6 GF30
Frage zu Nylon 12 (PA 12) glasfaserverstärkt (SLS) - ist das oben genannte Verfahren und Material am besten mit dem Material PA6 GF30 vergleichbar?
Mai 02
3D-Druck – dekorative Elemente
Hallo zusammen, ich möchte einige schlanke Dekorteile (sie sind 1,5-2 mm dick) für ein Musikinstrument mittels 3D-Druck herstellen lassen. Im Anhang findet ihr einen Screenshot eines der Modelle zur Ansicht. Könntet ihr spezielle Technologien... Mehr erfahren
874
Apr 30
PA12 und chemische Dampfglättung: Beständigkeit gegen Meerwasser?
Guten Tag, Ich habe eine kleine Frage: hält chemisch dampfgeglättetes PA12 (mit SLS/MJF) gut in Meerwasserbedingungen? Ich überlege, es für Teile zu verwenden, die häufig Meerwasserbedingungen ausgesetzt sind. Ich weiß, dass chemische Dampfglättung die... Mehr erfahren
Benötige Empfehlungen für eine feste Aluminiumlegierung
Hallo, ich entwerfe einen Flaschenöffner und möchte Aluminium verwenden. Ich brauche eine Legierung, die stark genug ist. Der Öffner wird nicht sehr dünn sein, ich denke an 3-4 mm an den dünnsten Stellen, so... Mehr erfahren
Mrz 11
Passivation of stainless steel for harsh environment
Hello!I'm working on a part that will be used in a harsh environment, so I was thinking of stainless steel 304 as a suitable material. I also would like to add a passivation finish... Mehr erfahren
Jul 12
