Translucent material recommendation - injection molding
Hi, I’m looking for recommendations on injection molding material. I’m in the process of placing an order and need to find material that offers specific properties. I require it to be translucent and UV resistant, along with impact resistance suitable for thicker moldings (7 mm). Additionally, the material should be non-staining and not yellow over time. What might be my options here?
Gelöst vonAnton Huryn
Hello, thank you for your interest in contacting us.
For your inquiry, we suggest you consider Makrolon® 6557:
  • flame retardant; UL 94V-0/3.0 mm;
  • UV stabilized; easy release;
  • Available in transparent, translucent and opaque colors
  • can be transparent / translucent up to about 4mm thick.
For quality molding, we also do not recommend exceeding a wall thickness of 4mm for this material.
Please try to modify the design by adding stiffeners / recesses instead of additional wall thickness.
We hope this will be helpful to you.
      • Diese Antwort wurde geändert vor 1 Monat von Anton Huryn.
      • Diese Antwort wurde geändert vor 2 Wochen, 2 Tage von Uliana Krayneva.
        Anton Huryn
        Hi Anton, Thanks for your prompt reply. Started to proceed with the quote right now. Will that be correct if I choose PC here  and just add the required material you advised in the notes? Also wondering, what finishing option should I choose? Thanks again
          Jakob L
      Thank you for your response.
      it looks like you filled out the request form correctly.
      in terms of surface quality
      Unfortunately, we cannot give you a precise recommendation on the finish, as we do not know the application conditions of the part.
      You can check our article on surface finishing, which is quite detailed and also order a die with finishing examples.
      Injection Molding Surface Finishes: SPI and VDI
      In general, if it is a view (transparent/semi-transparent) part, we recommend SPI A1…A2.
      If the transparent/semi-transparent part needs a small grain surfaces, we would recommend SPI D-1 or VDI 21/24/27 depending on your needs.
      Hope this helps you.
      • Senior Content Manager
        Anton Huryn
        Actually, we also have a transparent injection moulding card sample. Check it out:
Deine Information:
Vergleich von Nylon 12 (PA 12) SLS mit PA6 GF30
Frage zu Nylon 12 (PA 12) glasfaserverstärkt (SLS) - ist das oben genannte Verfahren und Material am besten mit dem Material PA6 GF30 vergleichbar?
Mai 02
3D-Druck – dekorative Elemente
Hallo zusammen, ich möchte einige schlanke Dekorteile (sie sind 1,5-2 mm dick) für ein Musikinstrument mittels 3D-Druck herstellen lassen. Im Anhang findet ihr einen Screenshot eines der Modelle zur Ansicht. Könntet ihr spezielle Technologien... Mehr erfahren
693
Apr 30
PA12 und chemische Dampfglättung: Beständigkeit gegen Meerwasser?
Guten Tag, Ich habe eine kleine Frage: hält chemisch dampfgeglättetes PA12 (mit SLS/MJF) gut in Meerwasserbedingungen? Ich überlege, es für Teile zu verwenden, die häufig Meerwasserbedingungen ausgesetzt sind. Ich weiß, dass chemische Dampfglättung die... Mehr erfahren
Benötige Empfehlungen für eine feste Aluminiumlegierung
Hallo, ich entwerfe einen Flaschenöffner und möchte Aluminium verwenden. Ich brauche eine Legierung, die stark genug ist. Der Öffner wird nicht sehr dünn sein, ich denke an 3-4 mm an den dünnsten Stellen, so... Mehr erfahren
Mrz 11
Hello,I'm working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I'm looking into CNC machining as injection molding seems not to be an option due to the precision... Mehr erfahren
Z
220
Jun 12
