electric motor
    • IEC 90L electric motor ( parts and assembly ) in 2d plan
    • Content Manager
      Hi Ali,
      could you please clarify what you need for the IEC 90L motor?
      Are you looking for 2D drawings, or support with designing or manufacturing the parts?
electric motor
Nov 18
3.0k
Jul 02
e
5.1k
Jul 03
1.9k
Solidworks or Inventor for sheet metal design?
Hey, I need to create a small sheet metal enclosure for a power supply unit—mostly bent parts in 1.5 mm steel, with tabs, cutouts, and a few fastener points. I’m new to CAD and... read more
t
2.8k
Jun 24
