For a mounting plate for a precision sensor (about 200 mm × 200 mm) I was going to call out a flatness of 0.05 mm, but my senior engineer says that’s overkill and will double the machining time/cost. The plate is 10 mm thick 6061‑T6. Is 0.05 actually “expensive” to hit on a standard mill, or is he just being old school? What’s a “safe” flatness for a general ground surface that won’t break the bank?
Dec 23
Dec 29
SLA wall thickness issue for microfluidic channels
Hi, I created a 3D design for a small microfluidic part using SLA (Clear Resin) with internal channels ~0.4 mm wide and wall thickness around 0.5 mm. The function relies on optical inspection through... read more
