Laser Cutting/Die Cutting for PP Parts
i
Hello, I have a small PP part with a thickness of 1.2mm. My initial idea was to manufacture these parts using laser cutting or die cutting, but I haven’t seen these manufacturing methods among the selectable options. Is there any possibility of doing it in this way?
Automatically translated from: Español
    • i
      Hi Isanvicent,
      Currently, our platform doesn’t support automatic quoting for laser cutting of PP (Polypropylene) material. However, we may be able to provide a manual quote or obtain one by directly contacting our suppliers. Please upload your components, select the SM (Sheet Metal) cutting process and specify PP as the custom material. Then, send us a message via the quote chat. We assure you that we will promptly address your request.
      Thank you.
      Joao Clemencio
Feb 19
Feb 20
s
960
Jan 23
