Machining deep cavities in aluminium
Hi all, I’m machining 60 mm deep, 20 mm diameter cavities in Aluminum 6061 with ±0.05 mm tolerances. Issues like chatter, tool deflection, and poor chip evacuation make it tricky, and I’m concerned about overheating and tool wear. Do you have any advice on tool selection, speeds/feeds, cooling, or strategies to balance precision and efficiency?
Feb 19
Feb 20
Jan 23
