Mechanical Technician Student
Hello, I am a mechanical technician student at the professional school of technology in Bochum. If you have anything interesting for the school program or for my future independence, I would be very interested.
I also have to do my technician project.
I would like to become independent and hire a few people who would like to work.
Solved by Peter Schmidt
Tolle Absichten und Interessengebiete! Wenn Sie ein bestimmtes Projekt im Sinn haben, das Sie selbst umsetzen möchten, können Sie es gerne mit der Community teilen; wir werden versuchen, mit Tipps beizutragen
    • Hello, I am a mechanical technician student at the professional school of technology in Bochum. If you have anything interesting for the school program or for my future independence, I would be very interested.
    • Hello Sven! It’s great to see your ambition. Do you have any specific projects in mind for your technician project? Also, what areas of mechanical technology interest you most—design, manufacturing, or maybe something else? It could help narrow down some ideas or resources for your school program and future plans. And are you already working on anything that you could potentially grow into your independent business later?
    • My Intention is electrical.
      Electrical Energy plant
      Electrical e Bikes Cars and buildings House ships and Air Planes
      And Flight objects or rockets
      I think this Could solve all Problems on earth
      For food industry
      Artiticial intelligent
      My Intention is to make Energy cheaper and more in value for every one and everything
      Like laser beams for welding cutting and melting Metal
      Like Tesla Motors or Tesla electrics
      I dont want to Work for some one Else
      I wanna solve dreams of Childs.  Without borders or limits
        Sven Pfeifer
Feb 20
