Process for a low-volume stainless steel pump impeller
Hi all, I’m designing a stainless steel impeller for a small pump (diameter around 80 mm). Would you go for metal additive manufacturing or casting if you need tight tolerances on the blades and good corrosion resistance? The quantities are low, maybe 50–60 pieces a year.
Feb 19
Feb 20
Jan 23
