Vacuum casting for small series: thermoplastics or just thermosetting?
g
I’m exploring alternatives to 3D printing for the production of small series. Can vacuum casting be used with thermoplastics or is it limited to thermosetting materials? I’m looking for ideas and experiences on this.
Mar 31
Feb 19
Feb 20
