Best material for vibration-dampers fan spacers
Help, I need to reduce vibrations transmitted to the enclosure and improve airflow efficiency for 3D-printed spacers for mounting cooling fans on an industrial control cabinet. These spacers need to provide some damping without... read more
Coated fasteners for stainless steel in coastal environments
We need to create a stainless steel structure for outdoor use in a coastal environment, and corrosion is our primary concern. We're considering coated fasteners but need to understand whether thicker coatings provide adequate... read more
Mar 18
Aluminium 5083 stiff enough for electronic keyboard enclosure?
I’m working on an enclosure for a compact electronic keyboard system, including a weighted key mechanism, and have chosen Aluminium 5083 for all parts due to its corrosion resistance and machinability. My main concern... read more
Feb 28
Best injection molding plastic for plastic enclosure
Hi everyone, we’re talking about a snap-fit design for a small electronic enclosure that needs to be opened and closed frequently—about 20 cycles per week. The part should be injection molded, and I’m deciding... read more
Mar 05
Machining marks in hard anodized finish
I’m experimenting with hard anodizing for an aluminum part and trying to understand how the finish affects the surface. Specifically, does the coating fully mask machining marks, or are they still noticeable through the... read more
Feb 21
