G
    • G
Coated fasteners for stainless steel in coastal environments
We need to create a stainless steel structure for outdoor use in a coastal environment, and corrosion is our primary concern. We're considering coated fasteners but need to understand whether thicker coatings provide adequate... read more
Mar 11
Aluminium 5083 stiff enough for electronic keyboard enclosure?
I’m working on an enclosure for a compact electronic keyboard system, including a weighted key mechanism, and have chosen Aluminium 5083 for all parts due to its corrosion resistance and machinability. My main concern... read more
Feb 28
Best injection molding plastic for plastic enclosure
Hi everyone, we’re talking about a snap-fit design for a small electronic enclosure that needs to be opened and closed frequently—about 20 cycles per week. The part should be injection molded, and I’m deciding... read more
V
Mar 05
Machining marks in hard anodized finish
I’m experimenting with hard anodizing for an aluminum part and trying to understand how the finish affects the surface. Specifically, does the coating fully mask machining marks, or are they still noticeable through the... read more
Feb 21
ABS vs Polycarbonate: tolerances for grip sleeves?
Hello!  I’m designing lightweight hiking poles and need to attach a plastic grip sleeve to an aluminum tube core. The grip has to stay super straight and centered along the pole for good balance... read more
V
Feb 17
