Deep pocket/cavity - CNC machining
Hi everyone,
I understand that there are limitations on the depth of cavities, and it’s generally recommended not to exceed a depth-to-width ratio of 4:1. However, I have a design that requires a pocket/cavity with a depth about 7 times the width. Could someone recommend any design strategies to achieve this while still allowing it to be milled? I know about using stepped pockets, but my design requires a flat bottom. Any advice would be appreciated!
    • N
      Hi everyone,
      Hi Noah,
      very hard to say just by a ratio, more important, if there is a fillet at the bottom and its size. If the bottom is sharped edged, what is the corner radius, then.
      If you would upload the part on https://xometry.eu/en/, our IQE is also rating the producibility of your part.
      Still sometimes you have better chances in 5 axis and finally EDM could also be an option.
      BR
      Niko
      • N
        Nikolaus Mroncz
        Thank you! Here’re a few screenshots –
        and the view from above:
        so, my pocket is about 7 times deeper than the width. Do you think it can be produced without any issues?
        Thank you for your help!
        Noah Johansson
        I think there will be issues in CNC, especially because of the small corner radii. This part looks more for me like an EDM part. Question is, if not it will not be too pricey then…
Hi, I'm currently working on a project involving the design of consumer electronics enclosures, and I'm looking to incorporate snap-fit features into the injection-moulded parts. What are the best practices for designing snap-fit features... Seguir leyendo
Jun 13
Hello,I am a mechanical engineer currently in the design phase of developing rectangular housings using PA66 GF30 material. From my previous projects, I've encountered challenges with achieving consistent dimensions, particularly with thin wall sections.... Seguir leyendo
877
May 03
Hello! I need some advice on CNC machining designs with mechanical engraving.should I integrate the lettering directly into my CAD designs, or is it better to engrave them after machining, separately? I’m planning on... Seguir leyendo
Abr 15
Switch 6061-T6 for 5052-H32 (bending), weight vs strength
Hi everyone –I'm evaluating the feasibility of bending a 5 mm thick 6061-T6 aluminium sheet into tie-off points for tensioned stabilizing lines, considering a bending radius of 15 mm. Given the known challenges of... Seguir leyendo
Abr 09
Tapping threads – DMLS parts
Hey everyone,I'm working on a DMLS project and need to tap M10 threads into the part. Can anyone recommend the best/most cost-efficient design strategies for this? Here are my considerations:Creating an 8.5 mm diameter... Seguir leyendo
Abr 04
