Z
Hello,
I’m working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I’m looking into CNC machining as injection molding seems not to be an option due to the precision required.
Maybe anyone could advise what flame retardant plastics should I consider for cnc that have UL recognition or certification? Ensuring the material meets safety standards is crucial for my application. Thank you, would appreciate any recommendations
    • Z
      Hello,
      Hi and thanks for your question. In CNC we have an ABS and Peek material rated UL94V0. Please add this demands in the comment, if you order at Xometry, there different grades are available.
      BR
      • Z
        Nikolaus Mroncz
        Hi,Nikolaus, thank you for your comment
    • Senior Content Manager
      Hi Zdenek,
      To complete Niko’s answer, you can check this detailed article about flame retardant materials https://xometry.pro/en-eu/articles/flame-retardant-plastics-ul-94/ You’ll find a list of materials which are, for most of them, UL 94 V-0 rated.
      I also would like to bring your attention to the fact that depending on your application, V-0 rating might not be necessary and you could consider V-2 or V-1 (or maybe even HB) rated materials. The grade of flame retardancy should be chosen based on the part, its application, and the environment in which it will be used.
      • Z
        Manon Bouriaud
        Hi Manon, good points indeed, thanks for sharing!
May 29
Hello, I would like a mirror polish on my copper CNC parts, roughness of Ra0.4 µm with mirror polishing. How do I specify this on the quoting site? Shall that be included in my... Seguir leyendo
May 15
Hi, I’m looking for recommendations on injection molding material. I'm in the process of placing an order and need to find material that offers specific properties. I require it to be translucent and UV... Seguir leyendo
660
May 15
Selecting FDM 3d printing materials for chemical resistance
Hello there! I'm currently exploring FDM printing for my project and wondering about materials that could withstand 30% nitric acid at 60°C. Would a PEEK-like material be suitable? Thanks in advance!
May 08
ABS vs PC in 3d printing prototypes
Hello everyone, I'm currently exploring options for 3d print durable functional prototypes and I'm choosing between ABS and PC materials. These prototypes will be subjected to mechanical stress tests and environmental conditions. Could anyone... Seguir leyendo
May 03
