Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think this is achievable by 3D printing? Or should I choose milling instead?
      Hi Jari,
      unfortunately we can’t print fittings.
      Better to choose CNC here.
      BR
Hi everyone, I would appreciate additional information regarding the optimal choice for my project. I’m going to print a tablet mount that must be robust and durable to hold my device. What might be... Seguir leyendo
May 17
Biomedical device fabrication
Hello everyone! I am Federico,I am looking for useful information regarding the fabrication technique and consequently the most suitable materials for manufacturing a device for use in biomedical research. Specifically, the device is about... Seguir leyendo
May 08
Hello,I am to order some laser cut sheet metal of steel, and got some technical questions, maybe someone can help: – TolerancesFrom what I have heard, the diameter of the laser beam is typically 0.2-o.3mm... Seguir leyendo
May 03
Looking for advice on reducing warping in injection molded HDPE parts, especially for components measuring 800x600 mm, where we see significant warping at the corners. Despite adjusting mold temperatures between 220-240°C  and experimenting with... Seguir leyendo
Abr 26
Any experiences with plastic CNC machining (POM)?
Hello!I'm planning to use CNC machining for plastic parts (Delrin/POM) for the first time and have typically worked with metals before. I'm considering the 'as machined' finish with a standard 3.2 µm surface roughness.For... Seguir leyendo
917
Abr 18
