Material Information
Good morning everyone,
I am intending to fabricate a model for biomedical applications, and the Xometry staff has suggested stereolithography as the fabrication method and Industrial Transparent ABS-like material, which can meet the basic requirements (strength, low moisture absorption, and transparency).
My concern is about its prolonged use, especially if in contact with liquids that will in turn come in contact with biological material. An additional problem is reuse of the part, that is, between uses it will be necessary to sterilize the part, and since it does not withstand autoclave temperatures, the only way available to me is with ethanol. Does this lead to damage to the material?
Thank you in advance for anyone who can help and give me an answer.
Good day to all,
Federico
    • Good morning everyone,
      Good day to all,
      Federico
      Hello Federico,
      Have you considered other manufacturing technologies, e.g. injection moulding? Or are you limited to only 3D printing?
        Tilmann98
        Good point, I also think that the choice for transparent materials in 3D printing is quite limited. You can add e.g. lacquering to ensure better usability and prolong its use, but still it’s not comparable to injection moulded transparent parts with e.g. ABS LG TR558A
Passivation of stainless steel for harsh environment
Hello!I'm working on a part that will be used in a harsh environment, so I was thinking of stainless steel 304 as a suitable material. I also would like to add a passivation finish... Seguir leyendo
Jul 12
Hello,I'm working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I'm looking into CNC machining as injection molding seems not to be an option due to the precision... Seguir leyendo
Z
662
Jun 12
May 29
Hello, I would like a mirror polish on my copper CNC parts, roughness of Ra0.4 µm with mirror polishing. How do I specify this on the quoting site? Shall that be included in my... Seguir leyendo
May 15
Hi, I’m looking for recommendations on injection molding material. I'm in the process of placing an order and need to find material that offers specific properties. I require it to be translucent and UV... Seguir leyendo
849
May 15
