Hi, I’m currently working on a project involving the design of consumer electronics enclosures, and I’m looking to incorporate snap-fit features into the injection-moulded parts. What are the best practices for designing snap-fit features to ensure ease of assembly?
Resuelto porDmitry Romanov
Good afternoon, you can check any standard approach about design of a snap-fit for injection molded parts. You can find by the link Design Tips for Injection Moulding released by Xometry – https://www.youtube.com/watch?v=i2IwM1_O-T0
The snap-fit joint should be designed in the way to avoid undercut for a molded part.
    • Good afternoon, you can check any standard approach about design of a snap-fit for injection molded parts. You can find by the link Design Tips for Injection Moulding released by Xometry – https://www.youtube.com/watch?v=i2IwM1_O-T0
Hi!Currently, I’m working on a new consumer electronics product, specifically a sleek, modern-looking smart home assistant. This device integrates voice control, home automation, and entertainment features. However, it's tough trying to find the right... Seguir leyendo
113
Jul 09
Hey guys! I’m hoping I can get some technical advice in designing an enclosure for a scientific instrument — it's a portable and remote logging device. The device I'm enclosing is about 100 mm... Seguir leyendo
8
251
Jul 03
Hi everyone,I understand that there are limitations on the depth of cavities, and it’s generally recommended not to exceed a depth-to-width ratio of 4:1. However, I have a design that requires a pocket/cavity with... Seguir leyendo
Jun 05
Hello,I am a mechanical engineer currently in the design phase of developing rectangular housings using PA66 GF30 material. From my previous projects, I've encountered challenges with achieving consistent dimensions, particularly with thin wall sections.... Seguir leyendo
May 03
Hello! I need some advice on CNC machining designs with mechanical engraving.should I integrate the lettering directly into my CAD designs, or is it better to engrave them after machining, separately? I’m planning on... Seguir leyendo
Abr 15
