Biomedical device fabrication
Hello everyone! I am Federico,
I am looking for useful information regarding the fabrication technique and consequently the most suitable materials for manufacturing a device for use in biomedical research. Specifically, the device is about 15x3x3 cm in size and has many empty spaces and channels inside. I am interested in identifying the fabrication method that will allow me to ensure a good accuracy of the geometry, possibly without spending too much money (no exaggeratedly high accuracy required, no too small components). In your opinion, could HP Multi Jet Fusion be a good solution? And possibly, can PP be a good material? I know it is often used for biomedical applications due to its hydrophobic and chemical inert capabilities; however, the part will need to be in a 37°C and high humidity environment for a long time.
Thank you very much to anyone who can help me!
Federico
Résolu parNikolaus Mroncz
Hi Frederico,
nice to meet you and thank you for your question.
For a humid environment it would help to have a closed surface. In MJF we have a postprocessing, called vapour smoothing which seals the surface completely.
It is not so successful with PP. But PA12 in MJF could be a good solution here.
If necessary we could you also a printing in ISO 13485. This would be in SLS and PA12.
Hope this answers your questions.
best regards
    • Hello everyone! I am Federico,
      Federico
      Hi Frederico,
      best regards
      Hello, Federico,
      How fine are the features/channels that you are referring to? Maybe you could also share a screenshot with some of the features – just to take a look and assess whether MJF/SLS can be a good solution here?
Comment assurer l’uniformité des couleurs en injection plastique?
Bonjour à tous, Je travaille actuellement sur un projet de production en série par injection plastique. Et je me demande comment je peux garantir la bonne couleur pour toutes les pièces, sachant qu’elles seront... Lire la suite
g
928
Avr 10
Formage de tôles ? nouveau
Bonjour, quelqu’un peu me dire si le formage de tôles est un procédé fiable pour la production de pièces comme celle-ci ? Non pas pour l’intégralité de la pièce sur le modèle, mais unique... Lire la suite
d
Juin 20
Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think... Lire la suite
Juin 04
Hi everyone, I would appreciate additional information regarding the optimal choice for my project. I’m going to print a tablet mount that must be robust and durable to hold my device. What might be... Lire la suite
Mai 17
Hello,I am to order some laser cut sheet metal of steel, and got some technical questions, maybe someone can help: – TolerancesFrom what I have heard, the diameter of the laser beam is typically 0.2-o.3mm... Lire la suite
Mai 03
