Choosing the right anodizing type for marine application
Hi all, I’m currently working on a marine application focusing on submersible components that require 6061-T6 aluminium. The part must undergo anodizing to ensure its wear and corrosion resistance when exposed to seawater.
At the moment I’m considering type III hard anodizing. However, I have some concerns regarding the possibility of fatigue cracks in the anodized layer due to the part experiencing tensile stresses up to 40,000 psi and compressive stresses up to 35,000 psi and high cycle fatigue (with stress cycles expected to exceed 10^5 cycles). I’m afraid that further cracks could not only lead to corrosion but also cause the part to crack.
Considering the need for both corrosion resistance and wear resistance, I’m determining the most suitable type and thickness for the anodized layer. Initial recommendations suggest a thickness of 25-50 μm for type III anodizing to provide a good balance between wear resistance and the ability to withstand mechanical stresses without significant risk of cracking.
However, I’m interested in hearing if there are alternative recommendations or insights based on practical experiences or additional research. Thank you!
Résolu parAttila Szucs
Hi Frederik,
You’re on the right path with Type III hard anodizing for your submersible components. The 25-50 μm thickness is generally good for balancing wear resistance and minimizing cracking risk under stress.
However, considering your concerns about high-cycle fatigue, you might explore a thinner layer or use a post-anodizing sealing process like nickel acetate or hot water sealing to enhance corrosion resistance. Also, consider duplex coatings or other protective measures suited for marine environments.
Regular stress tests and inspections will also be crucial to detect any early signs of failure.
Best of luck with your project!
Cheers!
    • F
      Hi Frederik,
      Cheers!
Matériau pour applications à haute température
Bonjour, je souhaite réaliser une pièce destinée à s’imbriquer dans un équipement industriel où la température peut atteindre jusqu'à 220-240 degrés Celsius. Je me demande quelle est l'option d'impression 3D la moins chère pour... Lire la suite
Juin 18
Forage
Bonjour, Nous aimerions savoir : Quel type de foret devrions-nous utiliser (trépans, carotteuses, forets hélicoïdaux) pour les opérations de prélèvement ?
e
Juin 17
Suspension
Bonjour, Nous cherchons des conseils pour choisir une suspension pour notre Rover. Nous allons rouler sur des terrains variés (sable, rochers…) et nous aimerions une suspension qui soit performante. Quels types de suspension recommandez-vous... Lire la suite
e
Mai 23
FSAE Upright Matériau
Nous sommes en train de finaliser la conception des trains roulants de notre monoplace pour la Formula Student et nous nous concentrons actuellement sur le choix du matériau pour l'upright, qui est un composant... Lire la suite
Mai 03
BRAS ROBOT
Bonjour, Y’a t’il un matériau en impression 3D, suffisamment résistant pour être capable de faire un bras robot avec qui devra résister à des charges de 29 kg/cm ? merci,
e
Mai 06
