Deep pocket/cavity - CNC machining
Hi everyone,
I understand that there are limitations on the depth of cavities, and it’s generally recommended not to exceed a depth-to-width ratio of 4:1. However, I have a design that requires a pocket/cavity with a depth about 7 times the width. Could someone recommend any design strategies to achieve this while still allowing it to be milled? I know about using stepped pockets, but my design requires a flat bottom. Any advice would be appreciated!
    • N
      Hi everyone,
      Hi Noah,
      very hard to say just by a ratio, more important, if there is a fillet at the bottom and its size. If the bottom is sharped edged, what is the corner radius, then.
      If you would upload the part on https://xometry.eu/en/, our IQE is also rating the producibility of your part.
      Still sometimes you have better chances in 5 axis and finally EDM could also be an option.
      BR
      Niko
      • N
        Nikolaus Mroncz
        Thank you! Here’re a few screenshots –
        and the view from above:
        so, my pocket is about 7 times deeper than the width. Do you think it can be produced without any issues?
        Thank you for your help!
        Noah Johansson
        I think there will be issues in CNC, especially because of the small corner radii. This part looks more for me like an EDM part. Question is, if not it will not be too pricey then…
Conseils sur fichier imbriqués pour découpe laser en alu 5052
Bonjour, j’ai téléchargé des fichiers imbriqués sur le moteur de devis instantané, mais on dirait que ça ne revient pas beaucoup moins cher que si j’avais importé mes fichiers séparément. Est-ce que je dois... Lire la suite
Avr 22
Impression 3D avec de l’aluminium
Bonjour à tous ! Quelqu'un saurait me dire quelle est l'épaisseur de paroi minimum pour l'impression d'une pièce 3D en alu AlSi10Mg ?
573
Indiquer fraisures sur dessin technique en tôlerie
Bonjour à tous, Je travaille sur la conception de pièces de tôlerie. Quelqu’un saurait me dire comment indiquer des fraisures sur mon dessin ?
Mar 22
Hi, I'm currently working on a project involving the design of consumer electronics enclosures, and I'm looking to incorporate snap-fit features into the injection-moulded parts. What are the best practices for designing snap-fit features... Lire la suite
Juin 13
Hello,I am a mechanical engineer currently in the design phase of developing rectangular housings using PA66 GF30 material. From my previous projects, I've encountered challenges with achieving consistent dimensions, particularly with thin wall sections.... Lire la suite
880
Mai 03
