Z
Hello,
I’m working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I’m looking into CNC machining as injection molding seems not to be an option due to the precision required.
Maybe anyone could advise what flame retardant plastics should I consider for cnc that have UL recognition or certification? Ensuring the material meets safety standards is crucial for my application. Thank you, would appreciate any recommendations
    • Z
      Hello,
      Hi and thanks for your question. In CNC we have an ABS and Peek material rated UL94V0. Please add this demands in the comment, if you order at Xometry, there different grades are available.
      BR
      • Z
        Nikolaus Mroncz
        Hi,Nikolaus, thank you for your comment
    • Senior Content Manager
      Hi Zdenek,
      To complete Niko’s answer, you can check this detailed article about flame retardant materials https://xometry.pro/en-eu/articles/flame-retardant-plastics-ul-94/ You’ll find a list of materials which are, for most of them, UL 94 V-0 rated.
      I also would like to bring your attention to the fact that depending on your application, V-0 rating might not be necessary and you could consider V-2 or V-1 (or maybe even HB) rated materials. The grade of flame retardancy should be chosen based on the part, its application, and the environment in which it will be used.
      • Z
        Manon Bouriaud
        Hi Manon, good points indeed, thanks for sharing!
Suspension
Bonjour, Nous cherchons des conseils pour choisir une suspension pour notre Rover. Nous allons rouler sur des terrains variés (sable, rochers…) et nous aimerions une suspension qui soit performante. Quels types de suspension recommandez-vous... Lire la suite
e
Mai 23
FSAE Upright Matériau
Nous sommes en train de finaliser la conception des trains roulants de notre monoplace pour la Formula Student et nous nous concentrons actuellement sur le choix du matériau pour l'upright, qui est un composant... Lire la suite
Mai 03
BRAS ROBOT
Bonjour, Y’a t’il un matériau en impression 3D, suffisamment résistant pour être capable de faire un bras robot avec qui devra résister à des charges de 29 kg/cm ? merci,
e
Mai 06
Matériau pour isoler thermiquement un circuit électronique
Je cherche un matériau pour isoler thermiquement un circuit électronique dans un boîtier qui sera soumis à une température de 250 degrés Celsius lors du processus de refusion. La mousse de caoutchouc de silicone... Lire la suite
Mai 03
Calcul couple moteur
Comment calculer le couple nécessaire d’un moteur en fonction du poids, d’un bras robot par exemple ?
e
558
Mai 10
