Translucent material recommendation - injection molding
Hi, I’m looking for recommendations on injection molding material. I’m in the process of placing an order and need to find material that offers specific properties. I require it to be translucent and UV resistant, along with impact resistance suitable for thicker moldings (7 mm). Additionally, the material should be non-staining and not yellow over time. What might be my options here?
Résolu parAnton Huryn
Hello, thank you for your interest in contacting us.
For your inquiry, we suggest you consider Makrolon® 6557:
  • flame retardant; UL 94V-0/3.0 mm;
  • UV stabilized; easy release;
  • Available in transparent, translucent and opaque colors
  • can be transparent / translucent up to about 4mm thick.
For quality molding, we also do not recommend exceeding a wall thickness of 4mm for this material.
Please try to modify the design by adding stiffeners / recesses instead of additional wall thickness.
We hope this will be helpful to you.
      • Cette réponse a été modifiée le il y a 1 mois par Anton Huryn.
      • Cette réponse a été modifiée le il y a 2 semaines et 2 jours par Uliana Krayneva.
        Anton Huryn
        Hi Anton, Thanks for your prompt reply. Started to proceed with the quote right now. Will that be correct if I choose PC here  and just add the required material you advised in the notes? Also wondering, what finishing option should I choose? Thanks again
          Jakob L
      Thank you for your response.
      it looks like you filled out the request form correctly.
      in terms of surface quality
      Unfortunately, we cannot give you a precise recommendation on the finish, as we do not know the application conditions of the part.
      You can check our article on surface finishing, which is quite detailed and also order a die with finishing examples.
      Injection Molding Surface Finishes: SPI and VDI
      In general, if it is a view (transparent/semi-transparent) part, we recommend SPI A1…A2.
      If the transparent/semi-transparent part needs a small grain surfaces, we would recommend SPI D-1 or VDI 21/24/27 depending on your needs.
      Hope this helps you.
      • Senior Content Manager
        Anton Huryn
        Actually, we also have a transparent injection moulding card sample. Check it out:
Suspension
Bonjour, Nous cherchons des conseils pour choisir une suspension pour notre Rover. Nous allons rouler sur des terrains variés (sable, rochers…) et nous aimerions une suspension qui soit performante. Quels types de suspension recommandez-vous... Lire la suite
e
Mai 23
FSAE Upright Matériau
Nous sommes en train de finaliser la conception des trains roulants de notre monoplace pour la Formula Student et nous nous concentrons actuellement sur le choix du matériau pour l'upright, qui est un composant... Lire la suite
Mai 03
BRAS ROBOT
Bonjour, Y’a t’il un matériau en impression 3D, suffisamment résistant pour être capable de faire un bras robot avec qui devra résister à des charges de 29 kg/cm ? merci,
e
Mai 06
Matériau pour isoler thermiquement un circuit électronique
Je cherche un matériau pour isoler thermiquement un circuit électronique dans un boîtier qui sera soumis à une température de 250 degrés Celsius lors du processus de refusion. La mousse de caoutchouc de silicone... Lire la suite
Mai 03
Calcul couple moteur
Comment calculer le couple nécessaire d’un moteur en fonction du poids, d’un bras robot par exemple ?
e
557
Mai 10
