Choosing the right anodizing type for marine application
Hi all, I’m currently working on a marine application focusing on submersible components that require 6061-T6 aluminium. The part must undergo anodizing to ensure its wear and corrosion resistance when exposed to seawater.
At the moment I’m considering type III hard anodizing. However, I have some concerns regarding the possibility of fatigue cracks in the anodized layer due to the part experiencing tensile stresses up to 40,000 psi and compressive stresses up to 35,000 psi and high cycle fatigue (with stress cycles expected to exceed 10^5 cycles). I’m afraid that further cracks could not only lead to corrosion but also cause the part to crack.
Considering the need for both corrosion resistance and wear resistance, I’m determining the most suitable type and thickness for the anodized layer. Initial recommendations suggest a thickness of 25-50 μm for type III anodizing to provide a good balance between wear resistance and the ability to withstand mechanical stresses without significant risk of cracking.
However, I’m interested in hearing if there are alternative recommendations or insights based on practical experiences or additional research. Thank you!
Risolto daAttila Szucs
Hi Frederik,
You’re on the right path with Type III hard anodizing for your submersible components. The 25-50 μm thickness is generally good for balancing wear resistance and minimizing cracking risk under stress.
However, considering your concerns about high-cycle fatigue, you might explore a thinner layer or use a post-anodizing sealing process like nickel acetate or hot water sealing to enhance corrosion resistance. Also, consider duplex coatings or other protective measures suited for marine environments.
Regular stress tests and inspections will also be crucial to detect any early signs of failure.
Best of luck with your project!
Cheers!
    • F
      Hi Frederik,
      Cheers!
Il miglior materiale stampato in 3D per i manubri delle biciclette
Nel mio progetto attuale, devo sviluppare un manubrio per bicicletta resistente e flessibile utilizzando la tecnologia di stampa 3D. Qual è il materiale per stampa 3D più resistente, in grado di imitare le proprietà... Scopri di più
Giu 13
Hello,I'm working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I'm looking into CNC machining as injection molding seems not to be an option due to the precision... Scopri di più
Z
220
Giu 12
Mag 29
Hello, I would like a mirror polish on my copper CNC parts, roughness of Ra0.4 µm with mirror polishing. How do I specify this on the quoting site? Shall that be included in my... Scopri di più
Mag 15
Hi, I’m looking for recommendations on injection molding material. I'm in the process of placing an order and need to find material that offers specific properties. I require it to be translucent and UV... Scopri di più
619
Mag 15
