Hi everyone, I would appreciate additional information regarding the optimal choice for my project. I’m going to print a tablet mount that must be robust and durable to hold my device. What might be the most suitable 3D printing process and material for this purpose? I’m considering nylon PA12 with glass fiber padding due to its strength and shock-absorbing properties. But I’m open to other more suitable material suggestions. Also would be interesting to know estimated cost and lead time for printing an average-sized tablet mount. Thank you!
Risolto daNikolaus Mroncz
Hi Patrick,
thanks for your question.
For a tablet mount I would prefer standard PA12. It is a bit more flexible and better in elongation at break.
For prices and leadtime you could upload your part on https://xometry.eu/ and immediately you see price and lead time.
BR
    • p
      Hi Patrick,
      BR
Colorare l’interno delle incisioni con Delrin
Salve a tutti, sto lavorando a un progetto di piastra di base in Delrin con incisioni di lettere sulla parte superiore. Il materiale è bianco. C'è un procedimento che voi fate per colorare di... Scopri di più
Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think... Scopri di più
Giu 04
Biomedical device fabrication
Hello everyone! I am Federico,I am looking for useful information regarding the fabrication technique and consequently the most suitable materials for manufacturing a device for use in biomedical research. Specifically, the device is about... Scopri di più
Mag 08
Hello,I am to order some laser cut sheet metal of steel, and got some technical questions, maybe someone can help: – TolerancesFrom what I have heard, the diameter of the laser beam is typically 0.2-o.3mm... Scopri di più
Mag 03
Looking for advice on reducing warping in injection molded HDPE parts, especially for components measuring 800x600 mm, where we see significant warping at the corners. Despite adjusting mold temperatures between 220-240°C  and experimenting with... Scopri di più
Apr 26
