Hi, I’m currently working on a project involving the design of consumer electronics enclosures, and I’m looking to incorporate snap-fit features into the injection-moulded parts. What are the best practices for designing snap-fit features to ensure ease of assembly?
Risolto daDmitry Romanov
Good afternoon, you can check any standard approach about design of a snap-fit for injection molded parts. You can find by the link Design Tips for Injection Moulding released by Xometry – https://www.youtube.com/watch?v=i2IwM1_O-T0
The snap-fit joint should be designed in the way to avoid undercut for a molded part.
    • Good afternoon, you can check any standard approach about design of a snap-fit for injection molded parts. You can find by the link Design Tips for Injection Moulding released by Xometry – https://www.youtube.com/watch?v=i2IwM1_O-T0
Ottimizzazione dell’orientamento dei pezzi per la stampa 3D
Salve, sono nuovo nella stampa 3D e sto cercando di capire come ottimizzare l’orientamento dei pezzi per ridurre la necessità di strutture di supporto e i tempi di produzione. Qualcuno ha consigli/strategie efficaci per... Scopri di più
Apr 29
Dimensioni delle fenditure per parti lavorate in CNC
Ciao a tutti, sto lavorando ad un progetto che richiede l'aggiunta di alcune fenditure a parti in alluminio utilizzando la lavorazione CNC. Qual è la larghezza di fenditura più sottile che posso progettare nel... Scopri di più
6
Mar 26
Hi!Currently, I’m working on a new consumer electronics product, specifically a sleek, modern-looking smart home assistant. This device integrates voice control, home automation, and entertainment features. However, it's tough trying to find the right... Scopri di più
113
Lug 09
Hey guys! I’m hoping I can get some technical advice in designing an enclosure for a scientific instrument — it's a portable and remote logging device. The device I'm enclosing is about 100 mm... Scopri di più
8
248
Lug 03
Hi everyone,I understand that there are limitations on the depth of cavities, and it’s generally recommended not to exceed a depth-to-width ratio of 4:1. However, I have a design that requires a pocket/cavity with... Scopri di più
Giu 05
