Standard and industrial SLA materials
Hi everyone, wondering what’s the real difference between standard and industrial SLA materials? Is industrial really that much better?
Risolto daNikolaus Mroncz
Hi and thank you for a good question. Normally the question is what is the difference in industrial and standard. Standard is using Desktop machines, industrial, industrial machines. But the resin, is it so different? Not really! They could be quite similar! To see how much they would differ, you can click on the link below the material. This will lead you to the datasheet.
    • N
Il miglior materiale stampato in 3D per i manubri delle biciclette
Nel mio progetto attuale, devo sviluppare un manubrio per bicicletta resistente e flessibile utilizzando la tecnologia di stampa 3D. Qual è il materiale per stampa 3D più resistente, in grado di imitare le proprietà... Scopri di più
Giu 13
Aluminium tempers
hidoes anyone know what temper the 7075 listed as an option on xometry is? they dont specify and theres a big difference in strength and hardness between T0 and T6 for examplethanksdan Scopri di più
d
Lug 22
Hydrocarbons and heat resistant material for intake pipe
Hello, I am planning to 3D print this moped engine intake pipe using plastic sintering. I would like to know which material is best suited for this purpose, considering it needs to be resistant... Scopri di più
Lug 22
Looking for advice: outdoor 3d printing materials
Hi, I need advice on 3D printing a part for outdoor installation that needs to be waterproof and weatherproof. Based on cost considerations, I'm deciding between FDM with ABS or PC, or SLS with... Scopri di più
Lug 18
Passivation of stainless steel for harsh environment
Hello!I'm working on a part that will be used in a harsh environment, so I was thinking of stainless steel 304 as a suitable material. I also would like to add a passivation finish... Scopri di più
Lug 17
