Translucent material recommendation - injection molding
Hi, I’m looking for recommendations on injection molding material. I’m in the process of placing an order and need to find material that offers specific properties. I require it to be translucent and UV resistant, along with impact resistance suitable for thicker moldings (7 mm). Additionally, the material should be non-staining and not yellow over time. What might be my options here?
Risolto daAnton Huryn
Hello, thank you for your interest in contacting us.
For your inquiry, we suggest you consider Makrolon® 6557:
  • flame retardant; UL 94V-0/3.0 mm;
  • UV stabilized; easy release;
  • Available in transparent, translucent and opaque colors
  • can be transparent / translucent up to about 4mm thick.
For quality molding, we also do not recommend exceeding a wall thickness of 4mm for this material.
Please try to modify the design by adding stiffeners / recesses instead of additional wall thickness.
We hope this will be helpful to you.
      • Questa risposta è stata modificata 1 mese, 1 settimana fa da Anton Huryn.
      • Questa risposta è stata modificata 3 settimane, 1 giorno fa da Uliana Krayneva.
        Anton Huryn
        Hi Anton, Thanks for your prompt reply. Started to proceed with the quote right now. Will that be correct if I choose PC here  and just add the required material you advised in the notes? Also wondering, what finishing option should I choose? Thanks again
          Jakob L
      Thank you for your response.
      it looks like you filled out the request form correctly.
      in terms of surface quality
      Unfortunately, we cannot give you a precise recommendation on the finish, as we do not know the application conditions of the part.
      You can check our article on surface finishing, which is quite detailed and also order a die with finishing examples.
      Injection Molding Surface Finishes: SPI and VDI
      In general, if it is a view (transparent/semi-transparent) part, we recommend SPI A1…A2.
      If the transparent/semi-transparent part needs a small grain surfaces, we would recommend SPI D-1 or VDI 21/24/27 depending on your needs.
      Hope this helps you.
      • Senior Content Manager
        Anton Huryn
        Actually, we also have a transparent injection moulding card sample. Check it out:
Il miglior materiale stampato in 3D per i manubri delle biciclette
Nel mio progetto attuale, devo sviluppare un manubrio per bicicletta resistente e flessibile utilizzando la tecnologia di stampa 3D. Qual è il materiale per stampa 3D più resistente, in grado di imitare le proprietà... Scopri di più
Giu 13
Hello,I'm working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I'm looking into CNC machining as injection molding seems not to be an option due to the precision... Scopri di più
Z
314
Giu 12
Mag 29
Hello, I would like a mirror polish on my copper CNC parts, roughness of Ra0.4 µm with mirror polishing. How do I specify this on the quoting site? Shall that be included in my... Scopri di più
Mag 15
Selecting FDM 3d printing materials for chemical resistance
Hello there! I'm currently exploring FDM printing for my project and wondering about materials that could withstand 30% nitric acid at 60°C. Would a PEEK-like material be suitable? Thanks in advance!
Mag 08
