Vapor smoothed and dyed black part MJF vs. SLS
Hi there,
Can someone tell me how does the black dyed MJF nylon with vapor smoothing compare with black dyed SLS nylon with vapor smoothing? Specifically with regards to surface finish and visible layer lines.
Risolto daNikolaus Mroncz
Thanks for your questions!
Here I share some images, how the parts may look:
The first is SLS and the second MJF. Finally the parts may look quite similar, still it also depends on the design.
    • Hi there,
      • Nikolaus Mroncz
        Thanks Nikolaus for sharing these pictures! Indeed, the surface looks quite the same. What about the cost? Is it less expensive to apply such finishes on an MJF or SLS nylon part?
      For this, please try our Instant Quoting Engine. You can upload the part on our website and see immediately the price, also if you change the technology. It depends on volume and design of the part, so not to answer, the one or the other.
Il miglior materiale stampato in 3D per i manubri delle biciclette
Nel mio progetto attuale, devo sviluppare un manubrio per bicicletta resistente e flessibile utilizzando la tecnologia di stampa 3D. Qual è il materiale per stampa 3D più resistente, in grado di imitare le proprietà... Scopri di più
Giu 13
Aluminium tempers
hidoes anyone know what temper the 7075 listed as an option on xometry is? they dont specify and theres a big difference in strength and hardness between T0 and T6 for examplethanksdan Scopri di più
d
Lug 22
Hydrocarbons and heat resistant material for intake pipe
Hello, I am planning to 3D print this moped engine intake pipe using plastic sintering. I would like to know which material is best suited for this purpose, considering it needs to be resistant... Scopri di più
Lug 22
Looking for advice: outdoor 3d printing materials
Hi, I need advice on 3D printing a part for outdoor installation that needs to be waterproof and weatherproof. Based on cost considerations, I'm deciding between FDM with ABS or PC, or SLS with... Scopri di più
Lug 18
Passivation of stainless steel for harsh environment
Hello!I'm working on a part that will be used in a harsh environment, so I was thinking of stainless steel 304 as a suitable material. I also would like to add a passivation finish... Scopri di più
Lug 17
