Any experiences with plastic CNC machining (POM)?
Hello!
I’m planning to use CNC machining for plastic parts (Delrin/POM) for the first time and have typically worked with metals before. I’m considering the ‘as machined’ finish with a standard 3.2 µm surface roughness.
For those who have experience with plastic CNC machining, can ‘as machined’ parts generally be used as end parts, or do they often carry too many machining marks? Would it be better to choose a bead-blasted finish (or another type) to enhance the appearance? These early prototypes might be shown to our end customers, so they need to look reasonably good. Any tips or experiences would be very helpful.
Also, could anyone share some pictures of polymer parts you have produced using CNC machining? I’d appreciate it!
Thanks, Marcin
Çözen kullanıcıPierre-Yves Huet
Hello Marcin,
Regarding the aspect, I would not recommend Bead blasting on this plastic material, because it will give a dull/grayer finish, which will be very noticeable if the material is black.
The “as machined” aspect is generally appreciated for this material, and it can be specified on drawing to avoid machining marks, which leads to using a finishing milling step to keep the milling traces as small and discrete as possible.
In my experience as support engineer, I can affirm that a lot of customers order parts in this material as an end part, without additional treatment or finish, but if the aspect is very important, you can specify a lower roughness, like Ra 1.6um, and indicate which surfaces should be ideally without tool marks.
Best regards,
Pierre-Yves
      Hello!
      Thanks, Marcin
      Xometry Engineer
      Hello Marcin,
      Best regards,
      Pierre-Yves
      • Bu yanıt 1 ay 3 hafta önce önce
        Pierre-Yves Huet
        tarafından değiştirildi.
      • Bu yanıt 2 hafta 2 gün önce önce Uliana Krayneva tarafından değiştirildi.
        Pierre-Yves Huet
        Thank you!
      What Mr Huet replied is accurate – I have similar experience. Here’s also a picture I just made of one of my recent ABS CNC machined parts, you can see that there are traces of milling, but they are not too visible.
        AM_EngR
        AM_EngR
        Thank you for sharing, that looks good, indeed. Nice texture 🙂
Robot kolu için motor torku hesaplama
Bir robot kolunun ağırlığına göre bir motorun ihtiyaç duyduğu torku nasıl hesaplarsınız?
May 02
katmanlı imalat plastik enjeksiyon fiyat performans
Plastik enjeksiyon ile katmanlı imalat arasında kaç adet üretimden sonra fiyat farkı optimize oluyor?
e
Nis 29
Büyük ABS parçalarda çarpılma sorunu
Merhaba, büyük boyutlu ABS baskılarındaki çarpılma sorununu azaltma konusunda önerebileceğiniz yöntemler nelerdir?
Mar 29
Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think... Daha fazla oku
Haz 04
Hi everyone, I would appreciate additional information regarding the optimal choice for my project. I’m going to print a tablet mount that must be robust and durable to hold my device. What might be... Daha fazla oku
May 17
