Biomedical device fabrication
Hello everyone! I am Federico,
I am looking for useful information regarding the fabrication technique and consequently the most suitable materials for manufacturing a device for use in biomedical research. Specifically, the device is about 15x3x3 cm in size and has many empty spaces and channels inside. I am interested in identifying the fabrication method that will allow me to ensure a good accuracy of the geometry, possibly without spending too much money (no exaggeratedly high accuracy required, no too small components). In your opinion, could HP Multi Jet Fusion be a good solution? And possibly, can PP be a good material? I know it is often used for biomedical applications due to its hydrophobic and chemical inert capabilities; however, the part will need to be in a 37°C and high humidity environment for a long time.
Thank you very much to anyone who can help me!
Federico
Hi Frederico,
nice to meet you and thank you for your question.
For a humid environment it would help to have a closed surface. In MJF we have a postprocessing, called vapour smoothing which seals the surface completely.
It is not so successful with PP. But PA12 in MJF could be a good solution here.
If necessary we could you also a printing in ISO 13485. This would be in SLS and PA12.
Hope this answers your questions.
best regards
    • Hello everyone! I am Federico,
      Federico
      Hi Frederico,
      best regards
      Hello, Federico,
      How fine are the features/channels that you are referring to? Maybe you could also share a screenshot with some of the features – just to take a look and assess whether MJF/SLS can be a good solution here?
Robot kolu için motor torku hesaplama
Bir robot kolunun ağırlığına göre bir motorun ihtiyaç duyduğu torku nasıl hesaplarsınız?
May 02
katmanlı imalat plastik enjeksiyon fiyat performans
Plastik enjeksiyon ile katmanlı imalat arasında kaç adet üretimden sonra fiyat farkı optimize oluyor?
e
Nis 29
Büyük ABS parçalarda çarpılma sorunu
Merhaba, büyük boyutlu ABS baskılarındaki çarpılma sorununu azaltma konusunda önerebileceğiniz yöntemler nelerdir?
Mar 29
Hi everyone, I have a new part I am looking to prototype. I am thinking of 3D printing out of Nylon 12. But there are features that require K7 hole tolerance. Do you think... Daha fazla oku
Haz 04
Hi everyone, I would appreciate additional information regarding the optimal choice for my project. I’m going to print a tablet mount that must be robust and durable to hold my device. What might be... Daha fazla oku
May 17
