Z
Hello,
I’m working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I’m looking into CNC machining as injection molding seems not to be an option due to the precision required.
Maybe anyone could advise what flame retardant plastics should I consider for cnc that have UL recognition or certification? Ensuring the material meets safety standards is crucial for my application. Thank you, would appreciate any recommendations
    • Z
      Hello,
      Hi and thanks for your question. In CNC we have an ABS and Peek material rated UL94V0. Please add this demands in the comment, if you order at Xometry, there different grades are available.
      BR
      • Z
        Nikolaus Mroncz
        Hi,Nikolaus, thank you for your comment
    • Senior Content Manager
      Hi Zdenek,
      To complete Niko’s answer, you can check this detailed article about flame retardant materials https://xometry.pro/en-eu/articles/flame-retardant-plastics-ul-94/ You’ll find a list of materials which are, for most of them, UL 94 V-0 rated.
      I also would like to bring your attention to the fact that depending on your application, V-0 rating might not be necessary and you could consider V-2 or V-1 (or maybe even HB) rated materials. The grade of flame retardancy should be chosen based on the part, its application, and the environment in which it will be used.
      • Z
        Manon Bouriaud
        Hi Manon, good points indeed, thanks for sharing!
Enjeksiyon kalıplama prototipleme – seri üretim malzeme farkları
Selamlar, Enjeksiyon kalıplamada prototiplemeden seri üretime geçerken malzeme özellikleri nasıl değişiyor? Nelere dikkat etmem gerekir? Bu konuda malzeme özelliklerindeki farkı en aza indirmek için nasıl seçimler yapmam gerekir? Daha fazla oku
Nis 18
Medikal prototiplere uygun SLA reçineleri
Merhabalar, medikal cihaz prototipleri üzerinde çalışıyorum ve doğru SLA reçinesi seçimi konusunda herhangi bir öneriniz var mı?
Nis 03
1,0 mm kalınlığında alüminyum 6061 T6 sac levha
Merhaba, "1.0mm kalınlığında alüminyum 6061 T6 sac" malzemenin dielektrik katsayısı, çarpma/darbe direnci, çekme direnci veya mukavemeti gibi blgilerini bilen varmı? veyahut  Datashetinide alabilrim çünkü bulamadım
Mar 15
Tıbbi katkılı üretimde Titan
Katmanlı imalatta medikal implantlar için titanyum kullanmanın avantajlarını ve eksi yanlarını açıklayabilir misiniz?
Mar 13
May 29
