Translucent material recommendation - injection molding
Hi, I’m looking for recommendations on injection molding material. I’m in the process of placing an order and need to find material that offers specific properties. I require it to be translucent and UV resistant, along with impact resistance suitable for thicker moldings (7 mm). Additionally, the material should be non-staining and not yellow over time. What might be my options here?
Çözen kullanıcıAnton Huryn
Hello, thank you for your interest in contacting us.
For your inquiry, we suggest you consider Makrolon® 6557:
  • flame retardant; UL 94V-0/3.0 mm;
  • UV stabilized; easy release;
  • Available in transparent, translucent and opaque colors
  • can be transparent / translucent up to about 4mm thick.
For quality molding, we also do not recommend exceeding a wall thickness of 4mm for this material.
Please try to modify the design by adding stiffeners / recesses instead of additional wall thickness.
We hope this will be helpful to you.
      • Bu yanıt 1 ay önce önce Anton Huryn tarafından değiştirildi.
      • Bu yanıt 2 hafta 2 gün önce önce Uliana Krayneva tarafından değiştirildi.
        Anton Huryn
        Hi Anton, Thanks for your prompt reply. Started to proceed with the quote right now. Will that be correct if I choose PC here  and just add the required material you advised in the notes? Also wondering, what finishing option should I choose? Thanks again
          Jakob L
      Thank you for your response.
      it looks like you filled out the request form correctly.
      in terms of surface quality
      Unfortunately, we cannot give you a precise recommendation on the finish, as we do not know the application conditions of the part.
      You can check our article on surface finishing, which is quite detailed and also order a die with finishing examples.
      Injection Molding Surface Finishes: SPI and VDI
      In general, if it is a view (transparent/semi-transparent) part, we recommend SPI A1…A2.
      If the transparent/semi-transparent part needs a small grain surfaces, we would recommend SPI D-1 or VDI 21/24/27 depending on your needs.
      Hope this helps you.
      • Senior Content Manager
        Anton Huryn
        Actually, we also have a transparent injection moulding card sample. Check it out:
Enjeksiyon kalıplama prototipleme – seri üretim malzeme farkları
Selamlar, Enjeksiyon kalıplamada prototiplemeden seri üretime geçerken malzeme özellikleri nasıl değişiyor? Nelere dikkat etmem gerekir? Bu konuda malzeme özelliklerindeki farkı en aza indirmek için nasıl seçimler yapmam gerekir? Daha fazla oku
Nis 18
Medikal prototiplere uygun SLA reçineleri
Merhabalar, medikal cihaz prototipleri üzerinde çalışıyorum ve doğru SLA reçinesi seçimi konusunda herhangi bir öneriniz var mı?
Nis 03
1,0 mm kalınlığında alüminyum 6061 T6 sac levha
Merhaba, "1.0mm kalınlığında alüminyum 6061 T6 sac" malzemenin dielektrik katsayısı, çarpma/darbe direnci, çekme direnci veya mukavemeti gibi blgilerini bilen varmı? veyahut  Datashetinide alabilrim çünkü bulamadım
Mar 15
Tıbbi katkılı üretimde Titan
Katmanlı imalatta medikal implantlar için titanyum kullanmanın avantajlarını ve eksi yanlarını açıklayabilir misiniz?
Mar 13
Hello,I'm working on a project that requires producing flame retardant plastic connectors with very precise tolerances. I'm looking into CNC machining as injection molding seems not to be an option due to the precision... Daha fazla oku
Z
220
Haz 12
