Best 3D printing material for child-safe educational toy prototype
Hello! I need advice on a small prototype for an educational toy aimed at children aged 3–6. It consists of interlocking geometric shapes (around 8–10 parts per set), with no mechanical function. I’m planning to 3D print a short run (1–5 sets) and need advice on the most suitable material. Parts need to be safe for handling by children, reasonably durable, and dimensionally stable enough for the shapes to fit together without tight tolerances. Between PLA, ABS, and Nylon, which would be the most appropriate option in terms of safety, tactile feel, and printability?
      For kids that young, I’d lean towards PLA. It’s food-safe (when printed with the right filament), doesn’t emit strong fumes, and is easier to print. It’s fairly rigid and dimensionally stable, which helps with fitting parts together. Plus, PLA can be sanded and painted easily for a nice tactile finish. ABS is tougher but emits fumes during printing, which might be a concern. Nylon is durable and flexible but can absorb moisture and warp, making it tricky for tight fits and small runs. If you want more durability, consider PETG as a middle ground, it’s tougher than PLA but less tricky than ABS or Nylon.
    • F
      Tactile feel matters a lot for kids. PLA feels rigid and smooth, which most children find pleasant to handle. Nylon can sometimes feel slippery or rough if the print isn’t perfect. Regardless of the material, make sure all edges are smooth and rounded to ensure safety. For a small run of 1–5 sets, PLA is likely your best choice because it’s easy to print, safe, and offers good dimensional accuracy for tight-fitting parts.
Surface Finish
Dec 17
