Design Strategies for Grid Structures - DMLS 3D Printing
Hello! Perhaps someone here can help me: Are there tips for effective design strategies for grid structures for parts printed in 3D via Direct Metal Laser Sintering (DMLS) to achieve an optimal balance between strength and material reduction, while ensuring manufacturability? Any experience or resource (specific to DMLS) would be helpful. Thanks!
12
110
12
355
Mar 16
