Designer Wanted
I want to work with a friend who has a millimetric design ability for a project I am currently working on.
Solved by Sinem Çiftçi
Hello Mr. Gökhan,
If you provide some details about the design or about your areas of expertise, it will be more appealing to designers. If we have a designer in our community with the appropriate expertise, they will think that the potential work is relevant to them and they will contact you.
Even if you can't get direct design service from Xometry, you can do price checks on xometry.com.tr throughout the design process and get design feedback.
Good luck with your project,
The Xometry Turkey Team
    • I want to work with a friend who has a millimetric design ability for a project I am currently working on.
      Hello Mr. Gökhan,
      Even if you can’t get direct design service from Xometry, you can do price checks on xometry.com.tr throughout the design process and get design feedback.
    • Hello Mr. Gökhan,
      I am experienced in 3D parametric CAD design and product development, I provide design services. How can I assist you? We can get in touch.
      Celalettin Toprak
      http://www.celalettintoprak.com
Designer Wanted
Mar 02
Dec 23
Dec 29
How to correctly specify standard and non-standard threads in a technical drawing?
For a machined part that has both standard and non-standard thread types, what’s the best way to call out threads in the technical drawing? In particular, should I use thread callouts or full detail... read more
I
6
1.5k
Nov 14
