H7/g6 fit - is it too tight for manual assembly?
Hi, I’m using a limits-and-fits guide to spec a bearing housing. I’m looking at an H7/g6 fit for a sliding location, but this is a field-repaired unit. If I go that tight, is some tech with a hammer going to destroy it in the field? Should I open it up to a looser clearance fit, or will that cause too much “slop” over time?
Feb 19
Feb 20
1.7k
Jan 23
