Laser Cutting/Die Cutting for PP Parts
i
Hello, I have a small PP part with a thickness of 1.2mm. My initial idea was to manufacture these parts using laser cutting or die cutting, but I haven’t seen these manufacturing methods among the selectable options. Is there any possibility of doing it in this way?
Automatically translated from: Español
Feb 19
Feb 20
Jan 23
