Looking for advice: outdoor 3d printing materials
Hi, I need advice on 3D printing a part for outdoor installation that needs to be waterproof and weatherproof. Based on cost considerations, I’m deciding between FDM with ABS or PC, or SLS with Nylon. Which of these material + technology will ensure the part is both waterproof and weatherproof? Thank you, Tim
6
367
May 05
