Machining marks in hard anodized finish
I’m experimenting with hard anodizing for an aluminum part and trying to understand how the finish affects the surface. Specifically, does the coating fully mask machining marks, or are they still noticeable through the matte layer? If you’ve dealt with this on visible components, I’d love to hear your experience—or even better, see a photo of a similar part
6
361
May 05
