Material for high-temperature applications
What is the best material for high-temperature applications in jet engine components?
Solved by Attila Szucs
For this application, I would recommend Inconel 718 – it is a nickel-chromium alloy with great strength and resistance to extreme temperatures (up to 700°C). It is also corrosion resistant. So this is a good material for components like turbine blades, casing and other critical engine parts. It can be used in various manufacturing processes, like machining, welding and additive manufacturing. Hope this helps!
    • What is the best material for high-temperature applications in jet engine components?
    • Senior Content Manager
      Stainless steel 316L can also be an alternative to Inconel 718, with a melting point of 1,400°C (1,430°C for Inconel). Stainless steel has a lower tensile strength though. If you are considering 3D printing, you can check this article that compares the best heat-resistant materials (both metals and plastics) https://xometry.pro/en-eu/articles/3d-printing-materials-heat-resistant/
Surface Finish
Dec 17
