Material for high temperature applications
Hello, I would like to make a piece that is intended to fit into an industrial equipment where the temperature can reach up to 220-240 degrees Celsius. I wonder what is the cheapest 3D printing option for this piece, capable of withstanding these high temperatures for an extended period. Thank you
Surface Finish
Dec 17
