Optimizing part orientation for 3D printing
Hello, I am new to 3D printing and am trying to understand how to optimize part orientation to reduce the need for support structures and production times. Does anyone have effective tips/strategies for doing this? In particular, I’m considering a model similar to this https://www.printables.com/model/622078-screw-cable-zip-tie. Any advice will be greatly appreciated!
1. Product Photography:
1.4k
2.0k
Mar 16
3.2k
