Polyjet for clear wearable casings
Has anyone here used Polyjet for transparent consumer electronics casings? I’m designing a small wearable device that needs a clear front cover to show internal LEDs and sensors. I know polyjet can do translucent and even clear finishes, but I’m wondering how well fine details (like small snap fits or embossed logos) hold up in practice.
Also, any advice on minimum wall thickness or post-processing tricks to get a truly clear finish? Thanks in advance!
Surface Finish
Dec 17
