en – EU
Türkiye Türkiye
United Kingdom United Kingdom
Global Global
Printed aluminum parts in pressure applications
Hi! Questioning about prototyping a hydraulic valve housing (normally CNC’d in 6061) – considering aluminum 3D printing instead, mainly to speed up design iterations. The part would see ~150 bar during bench tests, with critical faces finished by machining if needed. My main concern is whether printed aluminum can reliably handle those pressures without cracking or distortion. Has anyone tested this in similar fluid-handling applications?
Feb 19
Feb 20
s
576
Jan 23
Hello,I am writing because I am developing fingerboard wheels as a new product within my own brand. I professionally manufacture fingerboard decks and concrete obstacles, and now I am expanding my catalogue with cast... read more
