Hi! I’m working on a shrink-fit joint where a thin-walled 304 stainless sleeve is installed into a bored pocket in a much larger 4140 steel housing. The sleeve carries only light axial loads, but I want to size the interference so the hoop stress doesn’t crush or ovalise it. Most interference-fit guidance assumes shaft-and-hub geometry, which doesn’t translate well to a thin liner. How do you estimate hoop stress for a thin sleeve-in-bore to pick a safe fit?
Feb 19
Feb 20
1.4k
Jan 23
