Uniform surface finish on aluminum sheets
Hello, I need an aluminum sheet with a perfectly even surface finish since the final look is really important. The problem is, the sheets I’ve used so far have darker stripes or uneven patterns, which won’t work. Has anyone dealt with this before? Would foil sheets or pre-finished aluminum be a good option, or is there a better type of aluminum sheet I should look into?
6
349
May 05
