Help, I need to reduce vibrations transmitted to the enclosure and improve airflow efficiency for 3D-printed spacers for mounting cooling fans on an industrial control cabinet. These spacers need to provide some damping without compromising structural integrity. Would a flexible material like TPU be the best choice, or would a rigid polymer like PETG or ABS with specific print settings (infill density, layer height, wall thickness) offer better vibration isolation?
May 05
2.4k
