E-Books & Guides
Create Topic
Chrome plating finish
Hey there, does any one has experience with chrome plating? I’m considering it as finish option for my parts which will be used in wear applications, but I have few questions:
  • What base materials are compatible with the chrome plating process? I’m mainly working with stainless steel and some high-strength alloys.
  • What thickness range can be achieved with the chrome plating?
  • What is the hardness of the resulting chrome-plated layer?
  • What is the surface roughness I can expect post-plating?
Thanks in advance for any insights or recommendations on this!
May 05
2.4k
